Enable or Disable Snaps
Enable and disable grid, transformation, point, and 3D snaps.
Snaps are useful in the Move tool to place objects in specific locations and rotate an object around another for optimal orientation in 3D space.
At the lower right of the application window, choose from the following
options:
| Option | Description | Note |
| Grid #1 |
Snap to the closest grid line on Grid #1. | To change the grid settings:
| Grid #2 |
Snap to the closest grid line on the Grid #2 | |
| Grid #3 |
Snap to the closest grid line on the Grid #3. | |
| Grid #4 |
Snap to the closest grid line on the Grid #4. | |
| Translate | Snap to the closest point on the grid when translating. | Click the Snaps icon
| Rotate | Snap to the closest point on the grid when rotating. | |
| Scale | Snap to the closest point on the grid when scaling. | |
| Endpoints | Snap to end points. | |
| Midpoint | Snap to midpoints. | |
| Intersection | Snap to the closest point where curves intersect. | |
| Center | Snap to the center of a circle, ellipse, or arc. | |
| Curve | Snap to the closest point on the nearest curve. | |
| Tangent | Snap to the tangent of the nearest curve. | |
| Midaxis | Snap an extruded PolyNURBS face to the axis of the underlying STL object. This helps you create a more accurate PolyNURBS version of the STL geometry. | Only works with imported STL files in PolyNURBS mode. When importing the STL file, select the Import for rendering/reconstruction option. |
| Snap in 3D |
Enables snapping on the view's disabled axis (the axis perpendicular to the view plane). Otherwise, snapping is enabled only in the active plane. | |
| Snaps disabled | Disables all of the snap options you have activated, allowing you to quickly enable/disable your preferred snap configuration without having to set each snap option individually. |
