Local and World Axes
Switch between the local and world x, y, z coordinate systems.
To | Do this | Note |
Switch to the local axes | Click ![]() |
In a local coordinate system, a single object uses its own center as the origin. Any object in 3D space has both local and global coordinates. |
Switch to the world axes | Click ![]() |
In a world coordinate system, objects are located in relation to the world origin, which is a reference point unique to each object in 3D space. |
