Find
Find objects in the scene that contain the search string you enter. .
- Press Ctrl+1 to open the Model Browser.
Use the
Model Browser search
bar to
search for items.
You can filter results with the dropdown menu next to the search bar.
- Optional:
To control your search, click
, and then click one or more of the following
options:
- Match Case
- Whole Names Only
- Use Wildcards
- In the text field, type a search string.
Find Options
| Option | Description |
Navigate to the next or previous object that contains the search string. |
Find every object that contains the search string. |
Access additional options to control the search:
