Search and Filter
Search objects and automatically filter the results to only display the objects that contain the search string. You can also filter by object type.
Note: This only applies to the World and Lights tabs.
- Press Ctrl+1 to open the Model Browser.
Use the Model Browser search bar to search for items.
You can filter the search with the dropdown menu next to the search bar.
- Optional:
To control your search, click
, and then click one or more of the following
options:
- Match Case
- Whole Names Only
- Use Wildcards
- In the text field, enter a search string.
- Optional: Click the pull-down menu and select the type of objects to filter.
Tip: Reset the search by deleting the search string and setting the filter
to All.
