Extrude
Creates the holder surface by extruding a curve or a surface edge.
- On the ribbon, click the Die Design tab.
In the Flange Die section of the ribbon, click the
Holder icon.
Click the Extrude icon.
- In the guide bar, select the Flange Part object to assign to the holder:
Choose a selection method:
If you select this method Then do this Chain selection (default) Click an edge and all connected edges are selected automatically. Tangent selection Click an edge and the tangent edge is also selected automatically. Single selection Click an edge. Standard selection When you click an edge, all connected edges are automatically selected. -
Select the Flange Edges.
Choose a selection method.
Select the Extrude Edges.
Right-click to create the Holder.
The holder is created.
Adjust the holder position:
