Assign
Assigns the existing surface as a holder surface for the flange die.
- On the ribbon, click the Die Design tab.
In the Flange Die section of the ribbon, click the
Holder icon.
Click the Assign icon.
- In the guide bar, select the Flange Part object to assign to the holder:
- Select the Flange Edges.
- Right-click to confirm.
- Select the Surface to create the holder object.
The holder is assigned.
- Use the white arrows to adjust the position of the holder.
