Cloud Scaling Startup Script
Create a cloud-init script that is executed when the cloud node is deployed.
Introduction
Your site will want to do some configuration to their cloud nodes after booting. For example, you may want to install some packages, add users, or start services. A startup script can be added to a node class that will be run when the instance boots to perform automated tasks. Startup scripts can perform many actions, such as installing software, performing updates, turning on services, and any other tasks defined in the script. You can use startup scripts to easily and programmatically customize your cloud instances.
Startup Script on Windows Platforms
On Windows platforms, the startup script must be a PowerShell script. The content of the
PowerShell script should be enclosed in <powershell> and
</powershell>. For more information about PowerShell see PowerShell Scripting.
Startup Script on Linux Platforms
On Linux platforms, a utility specifically designed for cloud instance initialization is cloud-init. The cloud-init program is a bootstrapping utility for pre-provisioned disk images that run in virtualized environments, usually cloud-oriented services. Basically, it sets up the server instance to be usable when it’s finished booting. You must install cloud-init on your cloud provider VM to simplify the task of configuring your instances on boot. For more information see cloud-init.
- Shell scripts
- Cloud config files
The simplest way to configure an instance on boot is to use a shell script. The shell script must begin with #! in order for cloud-init to recognize it as a shell script.
Cloud-init Example for Accelerator
Here is a cloud-init for Accelerator nodeclass (without the templating). A <<DYNAMIC VALUE>> shows what needs to be updated based on your site configuration. The variables used in cloud-init need to be escaped.
#!/bin/bash
navops_host=10.0.0.70 <<DYNAMIC VALUE>>
# Default price to use in the case where the cloud provider didn't have price data so NavOps does not hold this data
default_price=0.555 <<DYNAMIC VALUE>>
default_spot_price=0.222 <<DYNAMIC VALUE>>
python=/usr/bin/python3
navops_conf_file=/opt/navops/etc/navops-agent.yaml
# NavOps populates these templated values with data, available to use to extend the utility of the cloud-init script for your own purposes
nats_token={{ nats_token }}
nats_urls=nats://${navops_host}:4222
accplus_host={{ vovhostname }}
bucketid={{ bucketid }}
user={{ user }}
group={{ group }}
projectname={{ projectname }}
vovportnumber={{ vovportnumber }}
vovdir={{ vovdir }}
cloud_environment_uid={{ cloud_environment_uid }}
instance_type={{ instance_type }}
machine_group_id={{ machine_group_id }}
preemptable={{ preemptable }}
name=$(hostname)
cost_resource_name=COST
slots_per_tasker=$(lscpu | egrep 'CPU\(s\)' | head -n1 | awk '{print $NF}')
# slots_per_tasker=1/1
# Set for manual burst taskers as this data is not available to the cloud-init for manual scaling
[ -z "$accplus_host"] && accplus_host=10.0.0.150 <<DYNAMIC VALUE>>
[ -z "$projectname"] && projectname=wx <<DYNAMIC VALUE>>
[ -z "$vovportnumber"] && vovportnumber=11495 <<DYNAMIC VALUE>>
[ -z "$user"] && user=accplusadmin <<DYNAMIC VALUE>>
[ -z "$group"] && group=/time/users.${admin_user}
[ -z "$vovdir"] && vovdir=/opt/rtda/2023.1/linux64 <<DYNAMIC VALUE>>
# Instance cost retrieval
price_filename=/tmp/instance-type-price.json
curl -s -o ${price_filename} "http://${navops_host}/api/v1/instance-type-price?cloud_environment_uid=${cloud_environment_uid}&instance_type=${instance_type}"
if [ $? -eq 0 ]; then
price=$(cat ${price_filename} | ${python} -c 'import json,sys;obj=json.load(sys.stdin);print(obj.get("price", "NULL"))')
if [ $? -ne 0 ] || [ $price == "NULL" ]; then
price=${default_price}
fi
spot_price=$(cat ${price_filename} | ${python} -c 'import json,sys;obj=json.load(sys.stdin);print(obj.get("spot_price", "NULL"))')
if [ $? -ne 0 ] || [ $spot_price == "NULL" ]; then
spot_price=${default_spot_price}
fi
else
fi
cost_resource=${cost_resource_name}#${price}
if [[ "$preemptable" =~ ^(true|True)$ ]]; then
cost_resource=${cost_resource_name}#${spot_price}
fi
# Install, configure and start navops-agent
curl --insecure https://${navops_host}/resources/agent/navops-agent.accelerator-tasker.linux_amd64.tgz | sudo tar xzf - -C /opt
/opt/navops/bin/agent-setup.sh --non-interactive
systemctl enable /opt/navops/etc/systemd/navops-agent.service
# Please uncomment and update the right hand side of this sed statement with your path for non-default install locations
# Note: This updates the agent to leverage the correct path
# /usr/bin/sed -i "s?/opt/accelerator/common/etc/vovrc.sh?/opt/rtda/2023.1/common/etc/vovrc.sh?" ${navops_conf_file}
if [ -z "$bucketid" ]; then
tasker_cmd="${vovdir}/bin/wxagent -W "tasker_" -p ${projectname} -h $accplus_host --port ${vovportnumber} --vovdir ${vovdir} --maxLife 1w --maxIdle 0 --taskerVerbosity 1 -U 15s -T ${slots_per_tasker} -w USER=$user:GROUP=$group:LOGPATH=/tmp -r ${cost_resource} >/var/log/wxagent.log 2>&1"
else
tasker_cmd="${vovdir}/bin/wxagent -W "tasker_$(printf '%09d\n' $bucketid)_" -p ${projectname} -h $accplus_host --port ${vovportnumber} --vovdir ${vovdir} --maxIdle 30s --maxLife 1w --taskerVerbosity 1 --taskerTimeout 120 -U 15s -T ${slots_per_tasker} -e $bucketid -w BUCKETID=$bucketid:USER=$user:GROUP=$group:LOGPATH=/tmp -r ${cost_resource} -r BUCKET:$(printf '%09d\n' $bucketid) >/var/log/wxagent.log 2>&1"
fi
sed -i '/tasker_cmd:/d' ${navops_conf_file}
echo " tasker_cmd: export VOVDIR=$vovdir && $tasker_cmd" >> ${navops_conf_file}
systemctl start navops-agent
Cloud-init Example for PBS Professional
Here is a cloud-init for PBS Professional nodeclass (without the templating). A <<DYNAMIC VALUE>> shows what need to be updated based on your site configuration.. The variables used in cloud-init need to be escaped.
#!/bin/bash
navops_host="10.0.0.70" <<DYNAMIC_VALUE>>
pbs_server_ip="10.0.0.250" <<DYNAMIC_VALUE>>
TOKEN=$(curl -X PUT "http://169.254.169.254/latest/api/token" -H "X-aws-ec2-metadata-token-ttl-seconds: 21600")
private_ip=$(curl -f -s -H "X-aws-ec2-metadata-token: $TOKEN" http://169.254.169.254/latest/meta-data/local-ipv4)
momHost=$(hostname)
momFQDN=$(hostname -f)
echo "$private_ip $momHost $momFQDN" >> /etc/hosts
echo "PBS_MOM_NODE_NAME=${private_ip}" >> /etc/pbs.conf
echo "PBS_SERVER_HOST_NAME=${pbs_server_ip}" >> /etc/pbs.conf
echo "PBS_LEAF_ROUTERS=${pbs_server_ip}" >> /etc/pbs.conf
curl --insecure https://${navops_host}/resources/agent/navops-agent.pbspro-mom.linux_amd64.tgz|tar xzf - -C /opt
systemctl enable pbs
systemctl start pbs
Cloud-init Example for Grid Engine
Here is a cloud-init for Grid Engine nodeclass (without the templating). A <<DYNAMIC VALUE>> shows what need to be updated based on your site configuration.. The variables used in cloud-init need to be escaped.
#!/bin/bash
NAVOPS_HOST="10.0.0.70" <<DYNAMIC VALUE>>
SGE_ROOT="/age" <<DYNAMIC VALUE>>
SGE_CELL="default" <<DYNAMIC VALUE>>
curl --insecure https://${NAVOPS_HOST}/resources/agent/navops-agent.age-exec.linux_amd64.tgz | sudo tar xzf - -C /opt
# /usr/bin/sed -i "s#sge_root:.*#sge_root: \/age#" /opt/navops/etc/meta.yaml
# /usr/bin/sed -i "s#^spool_dir:.*#spool_dir: /age/default/spool/$(hostname | awk -F. '{print $1}')/active_jobs#" /opt/navops/etc/meta.yaml
Cloud-init Example for Slurm
Here is a cloud-init for Slurm nodeclass
#!/bin/bash # Define a log file LOGFILE="/home/ec2-user/slurm-files/install.log" mkdir -p /home/ec2-user/slurm-files # Install dependencies for building Slurm echo "Installing dependencies for building Slurm..." >> $LOGFILE # Clone the json-c repository git clone --depth 1 --single-branch -b json-c-0.15-20200726 https://github.com/json-c/json-c.git /home/ec2-user/slurm-files/json-c >> $LOGFILE 2>&1 # Create a build directory mkdir -p /home/ec2-user/slurm-files/json-c-build # Run cmake with absolute paths cmake /home/ec2-user/slurm-files/json-c -B/home/ec2-user/slurm-files/json-c-build >> $LOGFILE 2>&1 # Compile and install using the build directory sudo make -C /home/ec2-user/slurm-files/json-c-build >> $LOGFILE 2>&1 sudo make -C /home/ec2-user/slurm-files/json-c-build install >> $LOGFILE 2>&1 # Clone the libjwt repository echo "Cloning libjwt repository..." >> /home/ec2-user/slurm-files/install.log git clone --depth 1 --single-branch -b v1.12.0 https://github.com/benmcollins/libjwt.git /home/ec2-user/slurm-files/libjwt >> /home/ec2-user/slurm-files/install.log 2>&1 # Run autoreconf with absolute paths echo "Running autoreconf for libjwt..." >> /home/ec2-user/slurm-files/install.log autoreconf --install /home/ec2-user/slurm-files/libjwt >> /home/ec2-user/slurm-files/install.log 2>&1 # Run configure with absolute paths echo "Configuring libjwt..." >> /home/ec2-user/slurm-files/install.log /home/ec2-user/slurm-files/libjwt/configure --prefix=/usr/local >> /home/ec2-user/slurm-files/install.log 2>&1 # Build and install libjwt with absolute paths echo "Building and installing libjwt..." >> /home/ec2-user/slurm-files/install.log make -j -C /home/ec2-user/slurm-files/libjwt >> /home/ec2-user/slurm-files/install.log 2>&1 sudo make install -C /home/ec2-user/slurm-files/libjwt >> /home/ec2-user/slurm-files/install.log 2>&1 # Log completion of dependencies installation echo "Dependencies installed." >> /home/ec2-user/slurm-files/install.log
