Inspire Mold is a modern simulation-driven design environment that lets you test, validate, correct, and optimize the design of
injection-molded components.
Some ribbon tabs are associated with license features. Depending upon the tab you have invoked, additional units may
be drawn. These features will be checked out for the duration of the session.
CAD import occurs in three steps: (1) pre-processing, (2) conversion from a third-party format to Parasolid where
applicable, and (3) post-processing of the Parasolid model.
Learn about the CAD import process and cleaning up CAD on import.
CAD Import Process
CAD import occurs in three steps: (1) pre-processing, (2) conversion from a third-party format to Parasolid where applicable, and (3) post-processing of the Parasolid model.
Clean Up CAD on Import
Run a diagnostic test on the imported model to review and fix issues with parts.
