Customize the Summary Table in the Report
You can perform the following actions to customize the summary table such as Job Table and Nodes/Tasker Table:
Reorder Columns
You can move a column in the table. Hold in the desired column and drag it to the desired location.
Set Pagination in Summary
You can set the number of records to display in the summary.
  1. Navigate to > Settings. The Settings window opens.
  2. Select the desired number in the Pagination Size list.
    Pagination Size
Show or Hide Attributes
You can select which attributes to display or hide in the table.
Click to display the attributes.
Reset to Default
You can reset the column order and column selection to default settings.
Click the Reset Default button on the attributes view.
Filter Column Data
You can use the filter icon on the top panel of the summary table to show () or hide () filters.
To apply a filter:
  1. Click in the desired column. The filter options appears:
  2. Select the desired filter, type the desired criteria in the Filter by box and press Enter. The filtered data is displayed in the report.
Click to clear the applied filter in the column.
Sort Data by Criteria
You can sort the data in the summary table.
Click the column header to sort it in ascending or descending order.
The indicates that the column is sorted in ascending order and indicates that the column is sorted in descending order.
Click to display the sorting options and select the criteria.
Note: You can view the sorting options only in the Job Summary report.
