Select a Report
Select a report from the list to generate the report chart and to view its metrics.
Figure 1. Select Report
The displayed metric varies depending on the selected report. For example, the following Metric is displayed for the Cluster Usage Report:
  • Number of Running Jobs
  • CPU hours
  • GPU hours
  • Memory in GB hours
  • Node hours
You can also search a report by entering the report name in the selection field.
Figure 2. Search for a Report
Select a report from the dropdown list to generate a report.
Figure 3. Report List
Report List
The following table provides the list of default reports:
Report Name Description Metric Details
Cluster Usage
Shows overall cluster usage for resource utilization as well as the number of jobs that were running during the selected time window.
If the total resources available is listed in the database then the chart will show the resources used as a percentage of resources available and there will be a data series showing unused resources. Otherwise the resources used by each data series will be shown as a percentage of the total resources used.
When there are more than 20 data series in the chosen grouping the chart will show the top 20 data series and group the rest into one data series called "other". In the table, all data series will be listed.
  • CPU Hours
  • GPU Hours
  • Memory in GB Hours
  • Node Hours
Cloud Cost
Shows the cloud cost as calculated by the instance cost and proportion of the cloud instance used by the job as a proportion of the cores used. This value is also known as the burn rate.
The jobs are accounted for at the end time.
The actual amount billed by the cloud provider may vary from the estimated cost shown here.
  • Number of Completed Jobs
  • Total Cost (USD)
Number of Jobs Completed Over Time
This report shows the number of jobs completed during the time window selected.
This report includes jobs that failed for any reason as well as jobs that succeeded.
Node Hours
This report shows Node hours for jobs that have completed: (Frac's of Nodes used) * wallclockTimeUsed.
(Frac's of Nodes used) = (slots used in the Nodes) /(slots available in the Nodes)
Incase job ran with exclusive flag, 'Frac's of Nodes used' will be 1.
All jobs that are running during the time window are included in the report provided they have now completed.
  • Node Hours
CPU Hours
Shows CPU hours: slots * wallclockTimeUsed.
  • CPU Hours
GPU Hours
Shows GPU hours: gpusRequested * wallclockTimeUsed.
  • GPU Hours
Memory Requested
Shows total memoryRequested * wallclockTimeUsed.
Unique Users Shows the number of unique users for jobs that completed during the time window selected.
  • Unique User Count
Time Spent Queuing
Shows the time jobs spent pending between job submission and job start: startTime - submitTime
All jobs that were pending during the time window are included in the report provided they have now completed.
  • Time Spent Queuing (Hr)
  • Number of Queueing Jobs
Expansion Ratio
Shows the expansion ratio: (endTime - submitTime) / wallclockTimeUsed
Expansion Ratio is the ratio of the time spent pending + running against the time spent running.
Shows the number of jobs with Expansion Ratio in the given range for jobs that completed during the time window selected.
  • Expansion ratio
Idle Jobs
Shows jobs where the the cpuTimeUsed is very low vs. the wallclockTimeUse for jobs that completed during the time window selected.
Reasons can be:
  • The job may have hung in deadlock
  • The job may have been waiting for a resource such as a license
  • One or more processes may have crashed leaving the job still running
  • The job may be interactive and left running, forgotten by the user
  • The job may have requested many slots, but is only using one core
  • Idle Jobs (CPU utilization <2%)
  • Idle Jobs (CPU utilization <10%)
Wallclock Requested vs. Used
Compares the wallclock requested as a percentage of wallclock used.
Shows the number of jobs with a percentage of wallclockTimeUsed vs wallClockTimeRequested in the given range.
  • % Wallclock Used
Memory Requested vs. Used
Compares the memory requested as a percentage of RSS memory used.
Shows the number of jobs with a percentage of physicalMemoryUsed vs memoryRequested in the given range.
  • % Memory Used
Job Runtime Shows wallclockTimeUsed grouped into runtime buckets for jobs that completed during the time window selected.
  • Job Runtime
Job Summary Report
Provides a table of primary metrics per job for jobs that completed during the time window selected.
The table will only show the first 1000 results. Please set filters to narrow down the results.
  • Cluster
  • Job Id
  • Array Index
  • Owner
  • Project
  • Job Name
  • CPU Requested
  • Memory Requested GB
  • GPU Requested
  • GPU Hours
  • Expansion Ratio
  • CPU Used(Hr)
  • Memory Used(GB)
  • Start Time
  • End Time
  • Run Time(Hr)
  • Submit Time
  • Queue Time(Hr)
Fairshare Groups Walltime Fairshare Groups Walltime in historical reports reflects the total walltime consumed by tasks in a Fairshare queue. This metric helps evaluate the overall resource usage and efficiency of jobs within the Fairshare framework. The value is rounded off to 2 decimal places.
  • Linux Group
  • Jobs with non-0 exit status
  • % Failed
  • Accumulated Wait Time (Hr)
Fairshare Groups Wait Time Fairshare Groups Wait Time in historical reports reflects the duration tasks spent waiting in a Fairshare queue before being scheduled. This metric helps assess system workload, resource contention, and how fairly resources are allocated among users or groups over time. The value is rounded off to 2 decimal places.
  • Linux Group
  • % Failed
  • Total Wait Time (Hr)
  • Max Wait Time (Hr)
Custom Reports
You can generate custom reports and save them. After you apply your desired filters and generate the report, you can do one of the following:
  • To save a new report , click under the Report list. Provide a name and click Save in the Save Report page.
  • To save changes to an existing report, click under the Report list. Click Yes in the Update Saved Report page.
  • To delete the report, select the report and click under the Report list. Click Yes on the Delete Saved Report page.
Note: Custom reports, if any, appear at the bottom of the report selection list.
