RD-V: 0130 Tied Surface Contact
Applying a tied surface contact between a plate and a block
The impact algorithm is evaluated by the impact of a cube on a square plate.
- /INTER/TYPE7
- /INTER/TYPE10 with ITIED =0 and ITIED =1
Options and Keywords
Model Files
Model Description
Units: Mg, mm, s.
The plate is 254 mm square and 25.4 mm thick. The cube length is 25.4 mm. The parts are modeled using solid elements and linear elastic material. An initial velocity of 5080 mm/s is applied to the block in the z direction. The model contains no further constraints.
Three different contact interfaces, /INTER/TYPE7, /INTER/TYPE10 with rebound and /INTER/TYPE10 without rebound, are tested to model the impact between the plate and the block.
In this analysis, /INTER/TYPE10 is compared with /INTER/TYPE7.
Iterations
Results
- Global Kinematics:
The global momentum can be plotted using the time history output. The results show that the global z momentum for all interface models correspond exactly to the theoretical momentum of 0.6452 mentioned in RD-V: 0100 Impact Momentum.
The results for the individual interfaces are not the same due to the differences in the contact stiffness of the interfaces. Using TYPE10 without rebound shows that the secondary nodes are tied to the main surface after the impact.
- Type7: As expected, during contact the impactor rebounds and the plate is pushed in the other direction.
- Type10 with rebound: The results are similar to those of TYPE7.
- Type10 without rebound: The plate is tied to the impactor as expected. After contact, the plate follows the movements of the impactor
- Type7: As expected, the impactor rebounds at contact and the plate does not move in the X-Direction. With TYPE7, sliding contact in the X-Direction is detected.
- Type10 with rebound: During the impact, the plate is tied to the impactor as expected. After contact, the plate follows the movement of the impactor.
Conclusion
The study shows that each of the contacts TYPE10 with rebound and TYPE10 without rebound behaves as expected. With TYPE10 with rebound, the impactor rebounds and the plate moves in the other direction. With TYPE10 without rebound, the plate is tied to the impactor and follows its movement.
