Initial Conditions
To avoid initial disequilibrium and mathematical discontinuity for zero mass or zero
volume, following initial conditions are set:
If the initial volume is less than
a constant small volume is added to obtain an initial
volume:
Initial mass energy density is defined from the above values.
There is no need to define an injected mass at time zero.
