Vicinity Transformation
Central to the computation of stresses and strains is the Jacobian matrix which relates the initial and deformed configuration:
The transformation is fully described by the elements of the Jacobian matrix :
So that Equation 1 can be written in matrix notation:
The Jacobian, or determinant of the Jacobian matrix, measures the relation between the initial volume and the volume in the initial configuration containing the same points:
Physically, the value of the Jacobian cannot take the zero value without cancelling the volume of a set of material points. So the Jacobian must not become negative whatever the final configuration. This property insures the existence and uniqueness of the inverse transformation:
At a regular point whereby definition of the field is differentiable, the vicinity transformation is defined by:
or in matrix form:
So, the Jacobian matrix can be obtained from the matrix of gradients of displacements:
