//SUBMODEL
Block Format Keyword The submodel card defines a part of the model with separate definition of numeration, unit system and Radioss version.
//SUBMODEL/submodel_ID/unit_ID/Vers_number
submodel_title
off_def off_nod off_ele off_part off_mat off_type off_sub
Definition
submodel_ID Submodel identifier.
(Integer, maximum 10 digits)
unit_ID Unit identifier. 4
Vers_number Optional version of input deck inside submodel. 5
Vers_number = V2025 for the current release.
Default = Version used in the main input file
submodel_title Submodel title.
off_def Default offset value for all option.
Default = 0 (Integer)
off_nod Default offset value for the nodes.
Default = off_def (Integer)
off_ele Default offset value for the elements.
off_part Default offset value for the parts.
off_mat Default offset value for all materials.
off_type Default offset value for all properties.
off_sub Default offset value for all submodels.
  1. The following options are not compatible with //SUBMODEL:
    /ADMESH
    All adaptive meshing cards
    /ALE
    All ALE cards
    /ARCH
    /CAA
    /EBCS/*.*
    /EBCS/MONVOL, /EBCS/INLET, /EBCS/FLUXOUT
    /BEM/DAA
    /INIMAP1D
    /INIMAP2D
    /FUNC_2D
    /GRTRIA
    /TRIA
    /EULER
    All EULER cards
    /INIVOL
    /INTER
    TYPE1, TYPE3, TYPE9, TYPE12, TYPE16, TYPE17, TYPE18, TYPE22, TYPE23, /HERTZ/TYPE17, and /LAGDT/TYPE7
    /LAGMUL
    All Lagrange multiplier method options
    /MADYMO
    /EXFEM, /LINK
    /MAT
    LAW18, LAW29, LAW30, LAW31, LAW52, LAW74, LAW78, LAW80, LAW81, USERIJ 8
    /PROP
    TYPE15, TYPE46
    /RADIATION
    /RANDOM
    /REFSTA
    /XREF or /EREF, instead of /REFSTA
    /RWALL/THERM
    /UNWIND
    /SECT
    Cut methodology - Isave > 0
  2. The following options are ignored when defined in //SUBMODEL:
    #RADIOSS STARTER
    #ENDDATA
    /DEF_SHELL
    /DEF_SOLID
    /DEFAULT/INTER
    TYPE2, TYPE7, TYPE11, TYPE19, TYPE25
    /ANALY
    /IOFLAG
    /END
    /ANIM/VERS
  3. The keyword //ENDSUB is mandatory at the end of the submodel block.
  4. The units and version of Radioss submodel can be specified either by /BEGIN card (recommended) or by Vers_number and unit_ID in the //SUBMODEL line. If they are defined in both places, the units and version defined in the /BEGIN card inside the //SUBMODEL are used instead of the Vers_number and unit_ID defined in the //SUBMODEL line.
  5. Available Vers_number values:
    Invers
    Radioss Format / Version
    V90
    Can be used from 9.0
    V100
    Can be used from 10.0
    V110
    Can be used from 11.0
    V120
    Can be used from 12.0
    V130
    Can be used from 13.0
    V140
    Can be used from 14.0
    V2017
    Can be used from 2017
    V2018
    Can be used from 2018
    V2019
    Can be used from 2019
    V2020
    Can be used from 2020
    V2021
    Can be used from 2021
    V2022
    Can be used from 2022
    V2023
    Can be used from 2023
    V2024
    Can be used from 2024
    V2025
    Can be used from 2025 (current format)
  6. Radioss Starter returns an error when two or more /BEGIN cards are specified inside the submodel.
  7. If the version of the input deck inside the submodel is not defined, the format is assumed to be the same as the one defined in the card /BEGIN in the main model.
  8. Material LAW29, LAW30, LAW31 and USERIJ can be used in the //SUBMODEL if the unit system of the //SUBMODEL is the same as the main file.
  9. //SUBMODEL supports hierarchy so a //SUBMODEL can be defined inside another //SUBMODEL. However, unit_ID and Vers_number are not available when a //SUBMODEL is defined inside another //SUBMODEL.
  10. When using hierarchy of //SUBMODEL, the input version of //SUBMODEL should be the current version of Radioss.
  11. If referencing an entity ID, such as node ID or part ID, in the Engine file, the entity ID must include the //SUBMODEL ID offsets.
