/SPHCEL
Block Format Keyword Describes the SPH cells.
/SPHCEL/part_ID
node_ID Type Mass
Definition
part_ID Part identifier.
(Integer, maximum 10 digits)
node_ID Supporting node identifier.
(Integer)
Type Input type for the mass.
= 1 (Default)
Mass.
= 2
Volume (mass will compute the material).
(Integer)
Mass (Optional) Mass or volume value. Used only if Mass > 0.
(Real)
[ kg ] or
[ m 3 ]
  1. The particles will have the same identifier as their supporting node.
  2. The particles should be distributed with respect to a hexagonal compact net or a cubic net (refer to SPH Cells Distribution).
  3. The particle mass is defined in the property (/PROP/TYPE34 (SPH)) is overwritten by the value defined in the cell (if defined).
