The boundary conditions are represented.Figure 2. Boundary conditions
Material Law Characteristics
The
material to be characterized is DP600 steel. The model is tested with different
elements mentioned above with 10x10 mm side lengths.
Material Property
Values
Young's modulus
210 GPa
Poisson ratio
0.3
Density
7.8e-06 kg/mm3
LAW36
The elasto-plastic behavior is defined using the tabulated material
LAW36. The True Stress versus Plastic True Strain curve is used as an
input of LAW36. For more information about the LAW36 material, refer to
RD-E: 1101 Elasto-plastic Material Law Characterization in
the Example Guide.Figure 3. True stress versus True strain
LAW2
This law represents an isotropic elastoplastic material using the
Johnson-Cook material model.
The materiel LAW2 parameters yield
stress “”, Plastic hardening parameter “” and Plastic hardening exponent “” have been defined. The true stress is
calculated using:
Where,
0.270 GPa
0.75 GPa
0.6
The true stress versus true strain curve is represented
below:Figure 4. Stress versus plastic strain curve LAW2
Johnson-Cook Failure
The
Johnson-Cook failure model is defined using /FAIL/JOHNSON in
the input. The model uses accumulative damages to compute failure:
with
Where, is the increment of plastic strain during a
loading increment, the normalized mean stress and the parameters the material constants. Failure is assumed to
occur when D=1. The strain rate and thermo-plastic effects are not considered in
this example. Only three parameters are required , and .
The material constants can be calculated
by using:
Where,
Pure tensile failure
Pure shear failure
Pure compression failure
The curve describes the material failure model using the Johnson-Cook failure model parameters
calculated above.Figure 5. curve describing the material
failure
Results
The Johnson-Cook failure criteria was evaluated with LAW2 and LAW36. As the results
are similar between both material laws, only material LAW36 results are represented
below.
Square coupon with SHELL
elements
The following element formulation is evaluated:
/PROP/TYPE1 (SHELL), QEPH shell formulation Ishell=24, 5 integration points over the thickness.
For each loading, the triaxiality and plastic strain curves are
represented at failure.
Table 1. Results for SHELL QUAD element
Pure Tensile
Pure Shear
Pure Compression
As expected, the elements failed once they reached the plastic
strain, then the stress decreases:
Pure tensile
Pure shear
Pure compression
Square coupon with SH3N
elements
/PROP/TYPE1 (SHELL), QEPH shell formulation Ish3n=0, 5 integration points over the thickness.
Table 2. Results for SH3N element
Pure Tensile
Pure Shear
Pure Compression
strain, then the stress decrease:
Pure tensile
Pure shear
Pure compression
Cube coupon with Solid Hexahedron
elements
/PROP/TYPE14 (SOLID), Isolid =24.
plastic strain curves are represented at failure.
Table 3. Results for Hexahedron element
Pure Tensile
Pure Shear
Pure Compression
Pure tensile
Pure shear
Pure compression
Cube coupon with TSHELL
elements
/PROP/TYPE20 (TSHELL), Isolid =15.
Table 4. Results for TSHELL element
Pure Tensile
Pure Shear
Pure Compression
Pure tensile
Pure shear
Pure compression
degenerated elements
Table 5. Results for HEXAHEDRON degenerated element
Pure Tensile
Pure Shear
Pure Compression
Pure tensile
Pure shear
Pure compression
Cube coupon with Solid Tetrahedron
elements
/PROP/TYPE14 (SOLID), Itetra4 =3.
Table 6. Results for TETRAHEDRON element
Pure Tensile
Pure Shear
Pure Compression
Pure tensile
Pure shear
Pure compression
Conclusion
This study highlights that the /FAIL/JOHNSON failure criteria
implemented in Radioss behaves as expected. As soon as
the element reaches the targeted failure plastic strain for a given triaxiality
level, the element is eroded. This study was carried out with material LAW2 and
material LAW36.
