Define a Categorical Input Variable and Set the Allowable Values
A categorical variable is an input variable that can take values from a non-orderable finite list of values, for example x = red, green, blue.
- In the Define Input Variables step, click the Modes tab.
- In the Data Type column for the input variable you are defining, select String.
In the Mode column, select Categorical.
Note: The Values cell turns orange, which indicates you can edit its values.
In the Values cell, click
In the dialog, define the categorical values.
- Click Apply.
- Click OK.
