Other Methods for Fitting a Curve
The following methods require certain parameters other than UTS to define the SN/EN curve.
  1. From the Assign Material dialog, click the My Material tab and select your created material.
  2. For Number of SN curves, select Single.
  3. For Curve Type, select Ratio/ Haigh Diagram.
  4. Select an input method.
  5. Click to view the model description.
  6. Define any necessary parameters.
    Note: The images below use the default values as a guideline.
Single Haigh Diagram
Figure 1. Single Haigh Diagram
Figure 2. Format of Haigh Diagram CSV
EN Properties
Figure 3. Slope
Figure 4.
