Highlights
HyperMesh CFD 2025.1 introduces the following new features:
        - Geometric Modeling
                            - Units support
- Automated gap patching
- Capability to find zero thickness parts
- Solid modeler environments (beta)
- Case Setup (External Aerodynamics)
                            - Enhanced output controls including direct import of .csv files for probes, and coarsening parameters for volume outputs.
- Post-Processing
                            - Comparison between two datasets
- Multi-plane slice for volumetric slice planes
- Multi-window framework (beta)
- EDEM particle support (beta)
- Report Utilities context (beta)
- Update to ParaView 5.13 libraries, compatible with OSMesa
- Design Exploration
                            - New morphing capabilities
- PhysicsAI workflow for KPI and field prediction
