Case Setup
Enhancement
- Probe Outputs
- Multiple enhancements have been made to the surface and volume probe
                                contexts:- Import probe .csv files directly in the guide bar to create probe instances.
- Output variables are accessible from the micro dialog advanced menu selection.
- Surface probes support a radius parameter.
- Outputs
                            - New option to delete original dataset after merging for relevant output instances.
- New set of options to coarsen volume output, both global and per instance settings.
- New variables, velocity magnitude, std. deviation and variance of pressure, for relevant output instances.
- Section cuts support parameter for triangulation.
- Monitoring surfaces have a default color and transparency to differentiate from regular surfaces.
- Miscellaneous
                            - XML output is less verbose, specifically default walls are skipped from the file.
- Ground patch has adjustable length and width controls as a fraction of the vehicle’s dimensions.
- Default names for offset and volume refinement zones have underscores instead of spaces.
- Systems and Move tool contexts have been redesigned and enhanced.
- Performance increases when interacting with models with large number of parts.
- Python API
                            - Create ground patch.
- Multiple variables are now editable, such as: numTimeSteps, machFactor, volumeOutput.xmin, and offsetRefinementZone.name.
Resolved Issues
- Polynurbs toolset have been enhanced and works without issues.
- Axis and Center specified in the xml file are not overridden automatically on import.
- Display/UI sync issues where number typed is not displayed correctly has been fixed.
- Segmentation error on creating overset fan is fixed.
- Repeated fan parts are captured and duplicate entries prevented.
- Special characters like <> in part names are captured and converted to underscores consistently.
- Push/pull tools on box faces work as expected for the turbulence, mesh refinement and volume output contexts.
- Installation issues with the Assets folder have been addressed. Client will now gracefully bypass errors due to missing files.
- Names of surface outputs and probe outputs are now imported from the xml file.
- Section cuts and probe outputs accept display color adjustments.
- Defaults button for advanced mesh control dialog has been fixed.
- Probes micro dialog correctly resets on creating another probe and all options are available.
- Probe locations are updated live in graphics when the table is updated.
- Offset layers and distance fields are in sync when one of them is updated.
- Turbulence source height is prevented from being set to 0.
- Negative coefficients are supported for a virtual fan model.
- Wind tunnel velocity is not reset while selecting the arrow.
- Probe files are imported without errors if the last line does not contain a line feed.
- Files in the exported folder are not automatically deleted when a new simulation is exported.
- Turbulence zone extents change correctly when edited from property editor.
- Frontal area in the controls panel has the correct units.
- MRF volumes have a separate category in the part browser.
