Geometric Repair
New Features
- Unit Support
- Unit Selection is supported for CFD 2025.1. You can now select the desired unit upon loading the model and then change unit within the sessions. On changing unit, geometries, mesh and settings will be scaled. Units are supported for General Purpose Solution: Case Setup as well. You can enter a value in any unit and on pressing Enter it will be changed to current global unit.
- Zero thickness parts detection
- One of the key requirements for auto enclosure workflow is to find and inflate zero thickness parts. A new option has been added to detect zero thickness parts for lite model.
- Automated gap patching
- New functionality added in gap tool to automatically patch gaps for selected parts. This functionality will reduce modeling time significantly for external aero modeling as well as cabin comfort. In , you can close gaps across two selection groups or if you selects parts in first selection group it will patch gaps between these parts.
Enhancements
- Geometry creation in lite mode
- Supported geometry creation capability in lite model – so user does not need to load CAD data to create geometries in lite model. User can use box, cylinder, lines, points, revolve region, simplify regions tools to create geometries.
- Split parts
- Enhanced Assembly  Merge/ Split tool for lite mode to automatically load CAD representation, split the CAD parts based on bodies, create CAD representation for new parts and reload lite representation of part.
- Template manager
- Supported all operations available in discrete ribbon and operations like Mirror, Scale, Save in operations. Supported all Find operations for part group creation.
Resolved Issues
- FE geometry model volume meshing failure has been resolved.
- Not able to rename part after duplicating part has been resolved.
