Extensions 2025.1 Release Notes
Enhancements
- Extension Script Statement Profile Support
- Both Python and Tcl scripts are now supported in all profiles with one
                            script statement: <entry name="script" value="init.py" />.
- Extension Documentation
- The documentation for how to use Python commands in the ribbon.xml and toolbar.xml files has been updated.
Resolved Issues
- The empty icons in the extensions drop-down menus no longer appear when images are specified in the actions of the menu.xml file.
- An exception error is no longer seen upon reloading the demo extension in solver profiles other than OptiStruct and Nastran.
- A load script error no longer crashes the application when removing an extension that would previously trigger such an error.
- Loading an extension using the HyperWorks GUI Toolkit now works either with an extension.xml file or a (deprecated) plugin.xml file.
