Altair SEAM 2025.1 Release Notes
New Features
- Sound Package Part
- The Sound Package Part tool, in conjunction with Noise Control Treatment, simplifies representing a physical sound package and its parts and applying the information to subsystems. Use the sound package to gain an overall view of the area's coverage percentage as well as the direction and location of the sound package part on all subsystems applied to a single piece.
- Advanced Material Formulations for Sound Package Part
- Two advanced material formulations have been added under Noise Control Treatment: perforated and rigid. These materials help you simulate the acoustic materials closer to real-world scenarios. Perforations can be defined by either single porosity or double porosity.
- Automatic Cavity Creation
- Creating acoustic spaces in SEA can be time-consuming for both an external or internal cavity. Use the new Cavity tool to create cavities using the volume approach for both internal and external acoustic spaces. Data input is based on the volume defined in each plane. Graphical manipulators aid data selection.
- Transmission Loss Tool
- Use the Transmission Loss tool to quickly select structural subsystems and calculate transmission loss, considering the isolated subsystems along with any sound package part applied to the subsystem.
Enhancements
The following enhancements have been added to aid the graphical visualization of SEA
                entities along edges:
        - Graphical Visualization
                            - The graphical visualization of SEA entities has been improved by adding colored edges to quickly identify the entity it belongs to.
- Excitation now supports applied loads on structural junctions.
- The Find attached option now supports junctions. Right-click to identify subsystems attached to junctions.
- Tools
                            - Edit now supports a split/merge of acoustic spaces.
- Auto connect now supports 1D junctions.
Resolved Issues
- Improved graphical selection of a subsystem during contouring.
- Improved subsystem selection for larger models.
