Altair HyperGraph 2025.1 Release Notes
General
Enhancements
- Qt 6 migration.
- Reader Enhancements
- HyperGraph now supports new versions of ATFX files.
- Seam Reader
- HyperGraph now supports a new set of files for SEAM readers.
- Python API
- New methods are now supported for the Window() class for XY, bar, complex, and polar plots, which get lists of all curves, datums, notes, and axes objects.
Resolved Issues
- Compose function registration.
- LS-DYNA interface issues.
- Issue with the ASCII reader for the OptiStruct interface. Support for new file formats.
- ISO MME files with unspecified units are now able to be read with the unit’s configuration file.
- Crash when editing a curve with the HIC function applied.
Extensions
Enhancements
- Extension Script Statement Profile Support
- Both Python and Tcl scripts are now supported in all profiles with one
                            script statement: <entry name="script" value="init.py" />.
- Extension Documentation
- The documentation for how to use Python commands in the ribbon.xml and toolbar.xml files has been updated.
Resolved Issues
- The empty icons in the extensions drop-down menus no longer appear when images are specified in the actions of the menu.xml file.
- An exception error is no longer seen upon reloading the demo extension in solver profiles other than OptiStruct and Nastran.
- A load script error no longer crashes the application when removing an extension that would previously trigger such an error.
- Loading an extension using the HyperWorks GUI Toolkit now works either with an extension.xml file or a (deprecated) plugin.xml file.
