2026
Evaluate designs by using geometric variables and applying a design-of-experiments (DOE) or optimization method. We recommend fully constraining your sketch when sketch variables are used in the design exploration.
Use the Evaluate tools to run the exploration and review reports.
Use the Results Explorer tool to review results.
Use the Results Explorer tool to review results for DOE.
Discover new features and enhancements in Inspire Form.
New to Inspire Form? Learn the basics here.
Start using Inspire Form with our interactive tutorials.
Create and assign variables to parametrize a model. This allows you to quickly iterate and compare design concepts by tweaking the values of the variables.
Create 2D sketches, surfaces, and solids.
Perform Feasibility, Blank Fit, and Blank Nesting analyses.
Use the Die Design ribbon to design and generate die surfaces.
Perform tryout analyses to validate die designs.
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
An exploration is a DOE or optimization simulation. Each exploration must include design variables and responses. Optimizations must also include an objective and optionally constraints.
Design variables are changes of the geometric variables that influence the performance of certain analyses.
An output response is a measurement of system performances, such as mass, volume, displacement, or stress.
Goals comprise objectives and constraints.
Export files to the output directory and run the exploration simulations.
Once an exploration is complete, review a summary of design variables and output response values in tabular format.
Visualize the relative effects that design variables and output responses have on DOE explorations.
Predict response values resulting from different design variable choices.
Plot exploration inputs and outputs.
Use the Results Explorer tool to review results for optimizations.
Adjust the materials, environment, and properties of objects in the scene to create a photorealistic image.
Analyze the object geometry for negative draft, trim angle, and shortest distance between parts.
View the glossary or frequently asked questions.
Learn keyboard shortcuts and mouse controls for common operations.
