Open the Design Explorer Browser
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
From the View menu, select Design Explorer Browser.
The Design Explorer Browser opens.
Any defined parameters are displayed here. Multiple explorations may be created in any given Inspire Form session. Use the Active option to select the active exploration and include or exclude desired design variables, responses, targets, or constraints before evaluating.
Note: Only one exploration can be enabled at a time.
