Create Surface from Skin
Use the Create Surface from Skin tool to extract a surface from a skin.
From the Feasibility
Prepare ribbon, Extract Face tools, click
the Skin tool.
Select the top or bottom surface of a thin solid.
The selected surface is highlighted.
- To add to the selection, hover over a surface and press Ctrl + left-click.
- To extract the skin, left-click the highlighted surface.
Tip: To delete the skin and restore the original thin solid, click the skin
while the Skin tool is active and press Delete. To reactivate the original thin solid, select . You cannot restore a thin solid from a skin once you close the
model.
