Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
Importing mechanical stress distributions into Flux 2D
Introduction
Materials with a magneto-mechanical property may be assigned to laminated magnetic non conducting regions in Flux 2D. In these regions, the distribution of mechanical stress may be used to modify the constitutive relationship B(H) of their materials. This feature allows users to model magneto-mechanical effects resulting from mechanical constraints (e.g., centrifugal forces or residual stress related to manufacturing).
The mechanical stress distribution ruling this effect in a laminated region may be evaluated with dedicated structural mechanics software such as SimLab/OptiStruct and then be imported into a Flux project as a spatial quantity. This page describes how to import the mechanical stress distribution results issued from that software into Flux to create this dedicated spatial quantity.
Import distribution from SimLab/OptiStruct
- A mesh file (.fem extension) representing the support over which the stress distribution has been evaluated. Typically, this mesh is associated to the ferromagnetic parts of the device (e.g., the rotor or the stator of a machine) and corresponds to their discretization used in the structural mechanics simulation carried out with SimLab/OptiStruct.
- A complementary data file (.txt extension) storing the stress values on the
previous mesh. The stress values must be expressed as scalar values on nodes
(typically the von Mises stress value) in MPa.Remarque : The contents of two files above are obviously linked, but are generated separately in SimLab/OptiStruct through two different post-processing actions. For more information on how to generate those files, please refer to the SimLab/OptiStruct user guide.
- in the Physics menu, select Mechanical stress distributions;
- then, choose command Import spatial distribution from SimLab/OptiStruct.
- provide the path to the Mesh file describing the support (.fem file), i.e., the first Simlab/OptiStruct file mentioned above.
- provide the path to the Data file containing stress values on the support (.txt file), i.e., the second SimLab/OptiStruct file mentioned above.
- provide a list of Regions with mechanical stress dependence, i.e., the Laminated magnetic non conducting regions with the Mechanical stress dependence option that will be influenced by the mechanical stress distribution imported as a spatial quantity.
- provide a string representing the Name of the stress spatial quantity that will be generated through the import process.
- the Data support name generated during the import;
- the Name of the imported data collection generated during the import;
- the Coordinate system used in Flux 2D that corresponds to the coordinate system implicit in the input files.
- create a spatial quantity containing the mechanical stress distribution and
- set active the Mechanical stress dependence option of the regions provided in the list. Their Constraint type parameter will also be set to Defined by a spatial variable card, and the generated spatial quantity will be used to describe their Equivalent uniaxial stress (MPa).
