Depuis la version 2026, Flux 3D et Flux PEEC ne sont plus disponibles.
Veuillez utiliser SimLab pour créer un nouveau projet 3D ou pour importer un projet Flux 3D existant.
Veuillez utiliser SimLab pour créer un nouveau projet PEEC (pas possible d'importer un projet Flux PEEC existant).
/!\ La documentation est en cours de mise à jour – des références au 3D peuvent subsister.
Essential Information about Flux 2024
| Essential information about Flux 2024 |
In order to use the version, you need:
Flux 2024 is available
for Windows and Linux OS:
Avertissement : In Flux PEEC, the Linux
distribution does not support the MUMPS LU Preconditioner of the
Compression solver for inductive computations. Please use a
different Linux distribution or another preconditioner.
The Linux version is qualified with the Gnome Classic with X11 display server. It is highly advisable to use the Gnome Classic with X11 display server to run Flux on Linux. |
| Flux 2024 takes into account the feedback from several users, and around 18 customer issues have been fixed in this version. |
| Distributed computing with MPI is available in Flux for
Windows and Linux and can be used with PBS. However, qualification on
Windows cluster connected with InfiniBand has not been done and
Linux clusters are highly recommended for parallel computing. (Supported version: Intel MPI to 2021.8) |
Minimum memory required:
