Concept of physical application
A physical application allows the solving of a problem described by an equation, the operating hypothesis and the boundary conditions.
The concept of physical application regroups information that concerns:
  • the solved equation and the solving mode of this equation (model, formulations, approximations, …)
  • the operating hypotheses: characteristics of the material media and the material behavior, characteristics of the sources, …
  • the boundary conditions: infinite box, conditions of symmetries and/or periodicity, other conditions imposed by the user, …
Categories of applications
The basic applications can be grouped into three categories:
  • magnetic applications
  • thermal applications
  • electrical applications
To these, the strong coupling between magnetic or electric with thermal application are added:
  • magneto-thermal application
  • electrothermal applications
General operation
The previously defined applications can be classified according to the field states:
  • static applications treat static (or steady state) phenomena in devices where the field sources are time independent
  • transient applications treat variables or transient phenomena in devices where the field sources are time dependent
  • steady state AC applications for devices where the time variation of the field sources is sinusoidal
Circuit coupling / kinematic coupling
Flux permits the user to carry out studies with circuit coupling and kinematic coupling.
  • Circuit coupling: The circuit coupling introduces the electrical equations directly into the magnetic field computation, enabling the analysis of electric conductors and the supply circuit. We refer to field – circuit coupling (or coupling with circuit equations).
  • Kinematics coupling: The Flux kinematic module enables the study of a moving part in a device subject to mechanical forces (springs, friction, gravity, etc.) and magnetic forces (magnets, coils, ...).
