Choice of application: strategies
Introduction
The applications available in Flux software are listed in § Synopsis of physical applications. The choice of an application depends on the problem type and on the desired results.
A transformer can be the object of at least two different analysis:
  • magnetic analysis, in order to evaluate the Joule losses;
  • electric analysis in order to evaluate the risks of collapse.
It will be treated by Steady state AC Magnetic application and by Electro Static application respectively.
