Material database: presentation
Database: definition
The materials database is a file comprised of a list of materials which includes: general data, physical properties, models and characteristics depending on the models. A material database is a file with the following format: DatabaseName.CMDD. The contents of a materials database is visible in the materials manager under the following form:
Database: settings
A database is characterized by:
- A name
- A path
Altair database and User databases
There are two types of materials databases:
- The Altair material database is supplied with the software and it is not modifiable
- The user material databases, are databases created by the user (DatabaseName.CMDD), and are therefore modifiable
