Local quantities available for postprocessing
Introduction
The local quantities available for the postprocessing in the Magneto Static application are stored in two categories:
- usual local quantities : the main characteristic quantities available in direct and easy access
- “advanced use” local quantities : the secondary quantities available in advanced use
Usual local quantities
Usual local quantities available are presented on the table below.
Advanced use
Usual local quantities available in advanced use are presented on the table below.
