Mechanical set: definition (structure)
A mechanical set is defined by:
  • a name (and a comment)
  • a type of mechanical set
and for the mechanical sets of rotation around one axis and translation along one axis :
  • an axis of rotation or translation
  • a type of kinematics (= computation mode)
  • kinematic characteristics:
    • general characteristics
    • internal characteristics
    • external characteristics
    • mechanical stops
Types of mechanical set
Different types of mechanical sets are presented in the table below.
Type enables the regrouping of the regions corresponding to …
fixed the motionless parts
compressible
the zone of air in which
the moving part is in motion
the moving parts
in rotation around an axis
the moving parts
in translation along an axis
free movement The free motion is designed to take into account complex motions (excluding translation and rotation movement). This motion is described by a list of positions for the mobile part
six degrees of freedom In space, using an orthonormal coordinate system (O,x,y,z), the 6 degrees of freedom are defined as follows:
  • Translation along the X axis, Y axis, Z axis
  • Rotation around the X axis, Y axis, Z axis
Types of kinematics
Different types of kinematics (= computation mode) are presented in the table below.
Kinematics (= computation mode) …
of type … enables the realization of a computation …
Multi static
of multi-position type in Magneto Static application
( parametrized study in Magneto Static application)
Imposed speed at imposed speed in Transient Magnetic application
Imposed position at imposed position in Transient Magnetic application
Coupled load
with magneto-mechanical coupling
Multiphysics to be able to coupling the motion with another software (like Activate)
General characteristics
General characteristics gather following information:
  • initial conditions (initial speed and initial position)
Internal characteristics
Internal characteristics gather following information:
  • kinematic characteristics relating to the moving part (proper characteristics) (see table below)
Motion Characteristics relating to the moving part
rotating moment of inertia
resistant torque
(formula or 3 coefficients)
translating mass
resistant torque
External characteristics
External characteristics gather following information:
  • kinematic characteristics relating to the coupled load (external device)
    (see table below)
Motion Characteristics relating to the coupled load
resistant torque
translating mass
resistant force
Mechanical stops
The various mechanical stops are following:
  • minimal stop
  • maximal stop
