Describing sources
Introduction
We distinguish two types of sources:
  • an imposed electric charge density (q0)
  • an imposed electric potential (V0)
The describing of these two types of sources in Flux software is detailed in the following blocks.
Imposed electric charge density
It is possible to impose a density of electric charge (q0) on a region by:
  • using the material regions of dielectric type (as presented previously): the volume density of electric charge of sources is then one of the data entered during the definition of the dielectric region
  • using the regions known as non-material of the type:
    imposed density of electric charge
Expression of the electric charge density
The electric charge density of sources represents the q term in the solved equation of electrostatic applications (see § Electro Static: solved equations).
The expression of this density depends on the used type of region. Information by the region type is gathered in the table below.
For a region… the density of the charges is a…
material
massive thin (withthickness) filiform (with cross-section)
volume density (or the total electric charge)
uniform or space dependent
non-material face (3D) surface density
line line density
Imposed electric potential
It is possible to impose an electric potential (V0) on a region by:
  • using the material regions of perfect conductor type (as presented previously): the electric potential is then one of the data entered during the definition of the region
  • using the regions known as non-material of the type: imposed electric potential
Expression of the electric potential
The expression of the electric potential depends on the used type of region.
For a region… the electric potential is…
perfect conductor uniform
imposed potential uniform or space dependent
