Flux-Activate co-simulation: about
Introduction
Flux offers a coupling with Twin Activate, compatible with Flux 2D and with Flux 3D. This coupling is available for all transient applications.
Implementation
Process tu run a co-simulation between Flux and Twin Activate :
- Preparation of the Flux project :
- Standard description: geometry, mesh and physics
- Specific description: creation of input and output parameters necessary to the coupling
- Generation of the component for the Flux – Activate coupling
- Preparation of Twin Activate model: :
- Set the Flux access path in the preferences in Twin Activate
- Add a co-simulation block from the palette browser.
- Configuration of the simulation parameters
- Running the co-simulation
- Post processing of results
Examples
Some examples are available starting from the supervisor, in the Open Example context.
