Steady State AC Magnetic coupled with Transient Thermal application: principles
Introduction
This chapter deals with the Steady State AC Magnetic (SM) coupled with Transient Thermal (TT) application and answers the following two questions:
- What is possible to model with Flux? (Flux capabilities, typical problem, mathematical models)
- How is a Flux problem described? (description of material media, sources, boundary conditions…)
For the analysis of the results (available post-processing quantities, interpretation of results…), refer to chapters:
Reading advice
Before reading this chapter, you should have read chapters:
