The Models
Two models are included with the example to provide content to export a report.
The following assumptions are made for both models:
- The first configuration contains 3D far field data.
- The far field can be wrapped in the θ direction.
- There is a ϕ angle calculated at ϕ=0° and at ϕ=90°. This also implies that the main direction of radiation is in the positive Z axis.
Note: Apart from these assumptions, any antenna geometry can be used as an input. The script can
be adapted to iterate over multiple models or to display different properties of interest.
