Modifying the Auto-Generated Mesh
Modify the model mesh in CADFEKO using the correct settings. A mesh is a discretised representation of a geometry model or mesh model used for simulation in the Solver.
- Set the Mesh size equal to Custom.
- Set the Triangle edge length equal to 4 cm.
- Set the Wire segment length equal to cap_length.
- Set the Wire segment radius equal to 0.01 cm.
