Defining Calculation Requests
Define the calculation requests in CADFEKO.
- The first configuration is a standard configuration for calculating the currents.
- The second configuration is an S-parameter configuration.
Define the standard configuration (default configuration).
Add an S-parameter configuration.
- Set a continuous frequency range for the S-parameter configuration from 290 MHz to 310 MHz.
- Set the ports PortI1 and PortQ1 to Active.
