Design Fundamentals
romAI serves two purposes.
romAI serves the following purposes:
- Reduced-Order Model (ROM) generation: Computationally expensive models are turned into ROMs that can be deployed into a system integration platform such as Altair Compose, IoT platforms, or third-party software through the FMI standard.
- System identification: Test data is converted into a mathematical model that can be deployed into a system integration platform such as Compose, IoT platforms, or third-party software through the FMI standard.
For simplicity, the term ROM generation is used in this document as an umbrella term that also implies system identification.
