From Surface Intersection
Extract curves from the intersection of two surfaces.
  1. On the Geometry ribbon, select the From Surface Intersection tool.
    Note: The tool may be hidden in the dropdown menu. To access the dropdown menu, you can do one of the following:
    • Select at the lower right corner of the currently displayed tool.
    • Click and hold the currently displayed tool.
  2. To combine all targets and newly created curves, in the guide bar select Options , then turn on Combine Curves.
  3. The Surface 1 button is active. Click the first surface.
    Tip: To change the first surface, click Surface 1, and then click another surface.
  4. The Surface 2 button is active. Click the second surface.
    Tip: To change the second surface, click Surface 2, and then click another surface.
  5. Select Apply .
    A new curve is created from the intersection of the two surfaces.
  6. Right-click and mouse through the check mark to exit, or double-right-click.
