Create Responses
Create output responses for the entire model, points, or individual parts.
From the Design Explorer ribbon, select the Responses
tool.
Tip: To find and open a tool, press Ctrl+F. For more information, see Find and Search for Tools. - To add individual responses for more than one sensor at a time, in the guide bar, enable Add a Response for Each Selection.
Select one or more sensors to create responses, then, in the guide bar, click
the
button to confirm the selection.
The Response window opens. -
In the Response window, configure the response.
Option Description Note Response Name field Change the response's name. Stage Select from the list of casting result stages. Result Type Select from the list of result types. Note: The list will change based on the stage selected above.Request Select from a list of request types. Goal Enable to set a goal of minimizing or maximizing the value of the variable(s) in the response. Add Constraint
Add a constraint to the response. Note: A maximum of two restraints are supported.Constraint Choose >= or <=. Note: Units will change based on the Result Type selected above. -
Click the List Responses satellite tool to open the
Design Explorer window to the
Responses tab.
