Manage Responses
Use the List Responses tool to display the Responses table, where you can create new responses, review all responses, and edit their names and properties in one place.
From the Design Explorer ribbon, select the List
Responses tool
You are now in the Responses step of the Design Explorer workflow. -
You can do the following:
To Do this Activate/deactivate a response for the active exploration Next to the desired response, turn on/off the Active option. Change the response type In the corresponding row, click the Response type, and then select a different one: - Mass
- Volume
- Stress
- Displacement
Change the component type Click the corresponding Component cell, and then select a different type. Change the request type Click the corresponding Request Type cell, and then select a different type. - Maximum (Absolute Value): Displays the absolute value of a response. For example, the absolute value of -3 or 3 is 3.
- First Value: Shows the first value for time-based analysis responses such as topology optimization.
- Last Value: Shows the last value for time-based analysis responses such as topology optimization.
- Maximum: Displays the largest value of a response.
- Mean: Displays the average of a range of responses.
- Minimum: Displays the smallest value of a response.
Create a new response Click the Create a response
icon.The guide bar is displayed. See Create Responses for next steps.
Rename a response Double-click the current name, and then type the new name. Show/hide callouts Click the Show/hide callouts
icon.Delete a response Right-click the corresponding row, and then select Delete.
