Open the Design Explorer Browser
The Design Explorer Browser displays a hierarchical view of your design setup and can be used to enable and disable exploration parameters.
From the View menu, select Design Explorer
Browser.
The Design Explorer Browser opens.
Any defined parameters are
displayed here. Multiple explorations may be created in any given Inspire Cast session. Use the Active option
to select the active exploration and include or exclude desired design
variables, responses, targets, or constraints before evaluating.
Note: Only
one exploration can be enabled at a time.
