Sort the List View
Sort the list view in the Files, Jobs, Input, Output, and Running Folder tabs.
Clicking on a column heading switches the sorting of the list view results by that column from ascending order to descending order.
Once you have selected a column heading for sorting, a triangle will appear next to the column heading.
                An up arrow
indicates that the
                list is sorted in ascending order. A down arrow
                indicates results are sorted in descending order.
Tip:  Sorting the list view is applicable in Files, Jobs, Input, Output, and
                Running Folder tab.
            In this example, we will sort the Job Monitoring list view.
                Click the Jobs tab located in the upper left-hand of the
                    page.
                The job monitoring page is displayed with the list of the jobs that is submitted to a cluster.
                Click the Application column heading to sort the list by
                    job application.
Figure 1. Job Listing Panel
The job listing will be sorted by job application in ascending order.Figure 2. Job Listing Sorted in Ascending Order
                Clicking the Application column heading again will sort
                    the list in descending order.
Figure 3. Job Listing Sorted in Descending Order
