Standard inputs
DC voltage
Voltage provided by the external DC source.
Speed
The imposed “Speed” (Speed) of the machine must be set.
Advanced inputs
Circuit resistance
Parasitic resistance of the circuit connecting the DC voltage source with the DC machine.
Circuit inductance
Parasitic inductance of the circuit connecting the DC voltage source with the DC machine.
Minimum number of computations per revolution
The user input “Min. no. comp. / revolution” (Minimum number of computations per revolution) influences the accuracy of results and the computation time.
The default value is equal to 50. The default value provides a good compromise between the accuracy of results and computation time. The minimum allowed value is 13.
No. computed revolutions
The user input “No. computed revolutions” (Number of computer revolutions) influences the computation time, it may also have an important impact to assure the steady state has been stablished (imperative condition to achieve accurate results).
The default value is 2. The minimum allowed value is 2 and the maximum value is equal to 4.
Mesh order
To get the results, the original computation is performed using a Finite Element Modeling.
By default, a second order mesh is used.
Airgap mesh coefficient
MeshPoint = (airgap) x (airgap mesh coefficient)
