VectorGlobalToLocal
Transforms vectors relative to the global system to a local system.
- src
 - A vector value table.
- nodes
 - A node entity table.
 - coords
 - A coordinate vector value table.
 - systems
 - A system entity table.
 - elemSysMethod
 - The element system method for the model. Valid values are "Bisect" (default value) or "Midpoint" (to be used for all Radioss models).
Outputs
- answer
- All vectors in coords must be relative to the global system.
 - All vectors in src must be relative to the global system.
 - nodes and src tables must be in the same pool.
 - elemSysMethod is only applicable for Element-bound vectors and is specific to quadrilateral elements only.
VectorGlobalToLocal(src,systems,nodes,coords,elemSysMethod)XML Example
<call name="VectorGlobalToLocal" src="vec_tab"
nodes="node_tab" systems="sys_tab"
coords="coord_tab" answer="ans_tab" />
