Globalize
Resolves coordinates and system transformations with respect to the global coordinate system.
- nodes
 - A node entity table.
 - coords
 - A coordinate vector value table.
 - systems
 - A system entity table.
Outputs
- coords
 - A coordinate vector value table (in/out).
 - systems
 - A system entity table (in/out).
- Systems and coordinates relative to non-global systems will be transformed to the global system.
 - This operator should be called within the model/commit block to insure all systems and coordinates are properly transformed to the global coordinate frame.
 - All vectors in coords must be relative to the global system.
 - This operator is not available in the expression builder.
N/AXML Example
<call name="Globalize" nodes="node_tab" systems="sys_tab"
coords="coord_tab" />
