TensorLocalToGlobal
Transforms tensors relative to a local system to the global system.
- src
 - A tensor value table.
- elems
 - An elemental entity table.
 - coords
 - A coordinate tensor value table.
 - systems
 - A system entity table.
 - elemSysMethod
 - The element system method for the model. Valid values are "Bisect" (default value) or "Midpoint" (to be used for all Radioss models).
Outputs
- answer
- All vectors in coords must be relative to the global system.
 - All tensors in src must be in the same pool as the corresponding entities in nodes or elems.
 - elemSysMethod is only applicable for Element-bound vectors and is specific to quadrilateral elements only.
TensorLocalToGlobal(src,elems,coords,systems,elemSysMethod)XML Example
<call name="TensorLocalToGlobal" src="tens_tab"
elems="elem_tab" systems="sys_tab"
coords="coord_tab" answer="ans_tab" />
